SS AFC Install How-To
does anyone know what wire i should cut to disable the SSAFC completely? just temporary im going to put something in so i can reconnect and disconnect whenever i want to. i suspect its causing CEL same as Zuku. Thanks, i have V1 if that matters
i did a little reading and from what i understand what i originally wanted was unattainable, because if you remove power from the ssafc you get no readings from your primary o2 since it calibrates the signal before it goes to the ecu, and it basically intercepts the wire
Sorrydidn't want to be rude but still it would be easier ,for me, with the picture and i know that alot of old treads have no more picture but why?
2007...
Dont expect the links to work...
The originator does not even have that car anymore...
Go get a Haltech. SS AFC is not the solution.
I'm happy-ish with my ssafc. I've never completed a full custom tune so I don't know if I will eliminate all of the quircks. I'm currently running 50/50 E85/91 @ 10.5psi making about 220whp. I maxed my injectors @ 5500rpm so I put in my 440s last night. Time to go retune....
Ok the ssafc is not the solution, but it's a viable option since everyone can't just go standalone
