ya, what i did was I had the autometer boost gauge vac line that comes with it.. that plastic thing, so when i installed the afc, I wanted to replace that line for the most part so I ran the new "good" silicone vac line through the firewall (was a pain but oh well) and then about 6inch or so after the firewall I T'ed it off there (I think if you ran it to the afc first and then back to the gauge it would be a) alot of unnecessary vac line, and b) get kind of crowded in the glove box) and secured it up near that bunch of wires under the steering wheel so it was out of the way, and just ran the line going to the afc behind center counsel kinda (I was able to see a clear gap when looking through to the other side) that popped out above the AC vent kinda thing, and I ran it above the metal frame piece that was to the left of the glove box.. over all i just found a route that worked well so nothing was pinching it off, or no way it could get tangle/caught on anything, and I also zip tied the vac line to the other wires as it went into the glove box because i noticed that it would kinda stray off to one side, so it just kept it in place a little better.. easy stuff... and as far as the source for the vacuum, I had mine originally into the intake mani as well, but when i installed my distribution block last weekend(along with some other stuff) I just switched it over to that and put that little "U" connection back the way it was, also.. I myself screwed in my afc to the glove box, they have self tapping screws but that plastic is just too flexible so i just quickly drilled 2 small holes with the afc box on the outside of the glove box..
I only mention the really small/easy stuff because they are usually the things that are easy to overlook, and are easy to address, and btw, it was very nice to drive with it, as everyone else said, it makes it all so much smoother!
