The lowdown:
Speed3
18x7.5
Stock tire
44mm offset.
I'm looking for a set of lowering springs and would like to know what drop the manufacturers offer, and how low should I be able to go without rubbing tire.
road magnet seems to be a good company. Not sure where you are located by they are made in DE or NJ I believe. I think the overall drop is right where you are looking to be.
I got H&R and it sits pretty fine. only 1 finger width is left in the back and 2 finger width in the front and my fingers are sort of skinny. One thing u have to look out for though is u have to change the shocks too cause i dont think the stock shocks can handle it unless u really baby ur car and avoid every potholes and bumps. I think I'm leaking oil from shocks. I'm in the market for shocks that can handle the drop. Anybody have any suggestions what shocks i should go for?
exactly, but with stock springs ms3 has more wheelgap on the front than on the back. hr spring front= 1.4 drop rear=1.3.....0.1 of a dfifference didnt make the front lower than the back after the hr springs install.
