Im having a similar issue. My car has an AEM CAI, Turbohoses aluminum intercooler pipes, 626 intake manifold, 3" catless downpipe, upgraded SMIC. Vacuum is -22 at idle, AFR's are 10.0 to 11.0 running 8psi on an Apex AVC-R. no hesitation, bucking, jerking, etc.
I do not build full boost until at LEAST 4200rpm. This is mainly noticable in 3rd and 4th gears when i am between 3300 and 4000rpm and go WOT. The boost instantaneously hits 0psi, but builds very slow to full boost (8-9lbs) then trickles off to 6-7lbs after 5500rpm.
If i am above 4200rpm and go WOT i get a 1-2psi spike almost instantly then it trickles down to the 6-7psi range. This is verifyable with the AVCR boost gauge and my AEM electronic boost guage. With the AVCR off, i get the same situation, but boost falls to 5lbs.
No noticable cracks in the exhaust manifold, car runs great other then not building boost before 4200rpm. Only thing i have not replaced on the intake side is the bypass valve. I have the forge replacement, but have not installed it yet. Any other ideas?
Thanks,
Jeffrey
