B brian2029 Member Oct 24, 2008 #1 Were Can I Buy The Adapter? Is Their Any Part Number I Have To Ask For?..
L L3vzoomzooom Member : 2007 MZ3 Sedan Oct 25, 2008 #2 I got mine here, cheapest I have seen.http://finishlineperformance.com/store/product.php?productid=16840&cat=288&page=1
N Nutari Member Contributor : 2010 Mazdaspeed3 Oct 25, 2008 #4 we also carry it. http://siteground207.com/~protegeg/product_info.php?cPath=22_310_69&products_id=1210 we also price match. Last edited: Oct 29, 2008
N Nutari Member Contributor : 2010 Mazdaspeed3 Oct 29, 2008 #9 L3vzoomzooom said: Both kits are the same item Click to expand... Not true. The speed 3 has a hole for the oil cooler line
N Nutari Member Contributor : 2010 Mazdaspeed3 Oct 29, 2008 #10 ehidle said: My car came with the spin-off filter.... Click to expand... Which car do you own? The 2.0 3?
E ehidle Member : 2008 Mazda 3i Touring Oct 29, 2008 #12 Nutari said: Which car do you own? The 2.0 3? Click to expand... '08 2.0 3 yep...
M MikeHTally Member : 2008.5 Speed3, 2006 Chrysler 300C, 2003 Ram 1500 Nov 11, 2008 #13 L3vzoomzooom said: I got mine here, cheapest I have seen.http://finishlineperformance.com/store/product.php?productid=16840&cat=288&page=1 Click to expand... That one won't work on the Speed.
B BlackFly Member Mar 28, 2010 #14 Torque settings for filter conversion I just bought the [spin-on] oil filter (conversion) for my '07 3 - 2.3. There were not torque settings included. Given the aluminum block, do you all know/have these settings? Do you recommend using RTV on the gasket, or install it as is? Thank you. Fred (evil)
L L3vzoomzooom Member : 2007 MZ3 Sedan Mar 28, 2010 #15 I used the OEM metal gasket that came with mine, and didn't use any sealant, no issues in two plus years.
S Supports Member May 7, 2010 #16 14-17lb on pretty much all "small" bolts that attachs to the block....cast aluminum is soft
