speed circuit front mount intercooler
mazdaplx
mazda protege lx 2003
as of my current job situation i cannot afford the speed circuit turbo kit so im going to get a megan racing exhaust, option racing headers, and the speed circuit intercooler. Now for the piping on the intercooler theres a part tht connects to the blow off valve, would i need a different piping kit because of this? Also for the headers there are two wires that are connected to the upper part of the manifold and lower part. right now im trying to disconnect this wire so i can remove the heat shield but that f***** is in there good and im not about to break it trying to force it out how do you remove these wires? and one last thing the intercooler piping comes with CRI and SRI options i want to run SRI so do i just put the airfilter on the part tht usually connects to the CRI?
How did you total it? From the clusterfuck of a paragraph that you wrote, it looks like you were trying to install an intercooler on a naturally aspirated car? What the **** is that about?
If you don't like this forum, you are more than welcome to get the **** out.
exactly gtfo!
umm i totaled it becus someone decided to collide with me headon when they were drunk not sure if its totaled now waitin for the estimate. everytime i ask a question about somethin i get attacked or no reply uh durr
people these days, really are mentally ******* retarded. it's obviously our fault that you wrecked your car. and it's our fault we didn't answer you because this thread is in the wrong ******* section anyways. of course.
did i say it was ur fault dipshit? no so **** off oh im srry what section should it be under? maybe car audio? cus i guess headers and exhasut have absolutely nothin to do with the engine or performance of the vehicle is tht right? cus u kno im menatally retarded ******* asshole
you're putting a header on a car that you're ALSO putting a fmic on. nope you're not retarded.
did u answer my q about what section? no cus ur ******* stupid so headers and a fmic wont work together? how? holy s*** if it dosent did someone actually just give me a tip? holy s*** thts a first
header and fmic normally do not work together. Why are you adding the fmic to your car? just kind of curious now TBH
I'll give you a tip. Research what you put on your car. An intercooler is used on a turbo setup. It cools the air that is coming from the turbo and entering the throttle body. It doesn't go on a naturally aspirated car.
Another tip. When calling someone "******* stupid" you should probably do a bit of proofreading before you post. You come off as completely uneducated and anything you say loses all validity immediately.
+1
Isnt this ******* obvious that this cum bubble is going to run a interfooler hence the headers (turbo cars don't have headers crackmonkey they have exhaust manifolds) and two headers on NA 4 banger hence the S.
Edit: og beat me to the punch.
