I have used many spark plugs in my 03 Mazda Protege DX.
I was wondering how they worked for you.
Out of all of the bunch I came up with the best as in.
NGK BKR6EK ( Needs better octane 89 - 91 )
NGK ZFR6F-11 ( Needs better octane 89 - 91 )
BOSCH F8DC4 ( NON-Resistor Needs better octane 91+ )
Air Bag light comes on & off. Nothing happens. Minor glitch!
NGK BKR6E-11 or
NGK BKR6E-11 MOD--- ( Needs better octane 89 - 91 )
http://performanceunlimited.com/documents/plugsidegapping.html
No spark hitting the piston. The spark hits the grounds before any where near the piston. Grounds better ground than the piston!
Only issue is octane. Advancing the combustion with sooner spark or faster combustion might make a pre-ignition.
( No cats? Need to burn more fuel to have less out of tail pipe to be read as too rich so ECU will turn down fuel less.
Also need 91 octane since less fuel is used. Less of 91 makes 87 in combustion. Better off not doing it! )
NGK BKR6E-11 or
