01GAZoomCar
- 2014 Mazda CX-5 Grand Touring
Does the 2014 CX-5 2.5l come from the factory with iridium spark plugs?
Someday I will replace plugs.... an apparent cakewalk compared to the 2002 Maxima it replaced. The latter required the removal of the intake manifold to get to the back three plugs.
FSM & owners manual says every 75K miles.
Here is a list of spark plug PN's from the FSM : PE01-18-110, PE02-18-110, PE5R-18-110, PE5S-18-110
I'd say that it can vary. My GTO was sputtering and when I pulled out an iridium plug, it was missing the iridium. All the plugs had huge gaps after 40K miles. I'd say that with the CX5, check the gap at 50k miles, you can even just check one. You can check them again at 75k miles. Be careful as that iridium tip should not bee touched; it is fragile.
