Sound system upgrade questions
Hello! I’m in the beginning stages of planning to rebuild my sound system in my CX-5. I have the Bose system and want to start from scratch. Should I use four speakers or replace all 8? Would the 8 be better? Thanks.
@Jwolfe94
To start:
Get a quality 4 channel amplifier (wire it in before the BOSE amp) to drive the following:
replace the front with 6.5" components (door / a pillar)
replace the rear doors with 5.5" coax
disconnect center speaker
turn off the BOSE functionality in the head unit
The doors are pretty well sound insulated; but I went ahead and did a dampening material around the front components (I'm running ~ 75 watts RMS).
Related reading:
The knowledge sharing document also has some information on subwoofer replacement choices should you choose to go down that path.
@Jwolfe94
To start:
Related reading:
Thanks for the documents. When you said turn off the functionality in the head unit, did you mean replace it? Or is that a setting.
