someone please help my protege is dying
2003 mazdaspeed protege
ive never used this forum b4 and im getting desperate
i bought my MSP in november from an older guy who was the original owner
i only paid 3500 dollars for it
BUT
it has never ran right since the day i got it
it stutters and bucks and hesitates
its dirt slow
and EVERY so often it will run good for a liitttle but then goes back to s***
it has 138k
everything is NOW stock
i tried modding it but it just made things worse
it throws a "random cylinder misfire" code
when u rev the engine up and kick the pedal i spit flames...it sounds like gunshots tho its so loud
i replaced the coil packs
spark plugs
spark plug wires
egr valve
timing belt water pump etc
and it still does run any better
i also changed this VICS sensor..stil no better
i CANNOT fix this car idk whats wrong with it..neither does mazda or any of my friends
the car legit sucks
it makes boost and everythhing
but it goes NO WHERE ..
u hardly feel the turbo.
the whole car sounds like it struggles..id say its a 16 second car at best
help me fix this thing
Where are you located at? if your in or around kansas city missouri i'd be willing to help you take a look at it.
But yes start checking through all the threads in this forum that have similar problems. it might be a cracked exhaust mani. And taking it to the mazda dealership and having it diagnosed if you can't find whats wrong would be a great investment. gives you a starting point.
Dumb question, but are you filling up with 93 octane? We had a guy with similar issues that was cheaping out and using 87. He switched and the car ran fine...
i use 93 octane evveryday
my exhaust manifold is okayy
i sorta think its my fuel pump?? im not sure..
OR my exhaust manifold has a crack underneither it??
but i doubt this because once 2 of the bolts fell off and my exhaust mani leaked and u could hear it
it still sounds quite so i doubt its leaking anywhere
im really starting to hate this car...its been 8 months and it still runs terrible :[[[[[
oh yeah and my compression WAS fine when i bought the car...but from it shooting flames all the time everyone tells me is gonna ruin my compp. so idk if its still good anymore
Is it possible your timing is off? What does it do just cruising and not under hard accelleration. How is the idle? Also does it have starting problems?
finally fixed..changed my coil packs wires spark plugs timing belt water pump egr valve intercooler hoses and what did it turn out to be?
mazda had to reflash my ecu -_-
that wide open throttle open loop s*** -_-
finally fixed
Weird and first I heard of something like this...
finally fixed
Good thing your MSP running well, feel free to meet up here or at strabucks in edgewater.
I'm around clifton as well.
