I had this issue with my gt2554r checked the ic piping and there was oil in the hot side, but when i checked the cold side it was completely dry, not a spec of oil. Anyhow I found a brand new gt28rs and replaced the stock and had the same thing, there was a little bit of oil coming out of the turbo and in the ic piping, this is a brand new turbo soo i knew it wasnt the turbo. I checked the oil and seemed over the last couple of weeks being scared of running dry on oil i topped up frequently, it was a little bit too much. I pulled the dipstick up a bit to vent out the excess oil to see if it would work, and no more smoke at all, checked the ic piping and no oil. I am also getting a code, I think its the pcv, which Ill change asap. Thinking it was a pcv problem this whole time, it was pressurizing the system which caused blowby but as soon as some pressure was relieved it was good. Let me know what you guys think. Also do you guys run a restrictor on your gt28rs and if you do how did you guys deal with the whole 4an male out and out stock male m11x1 thread, I have no idea how to attach it without changing the line to a 4an, Im in the process of fabricating my own fitting.
