Tonight I was rotating my tires, and had the front end jacked up on both sides.
While tightening the front lugs, I was surprised to find that as I really tightened them down, the tires would actually rotate - it took a lot of force but it would.
I know normally w/ a typical open differential, if both wheels are up off the ground turning one should allow the other to rotate the other direction. But that should be relatively frictionless - and this is a 5spd w/ it in gear.
What allows this slip? Does that indicate the clutch is slipping?
I've been having issues w/ it popping out of gear but I chocked that up to worn synchros or motor mounts (185k miles)...
