J/w as why you didnt try and heat pipe to the shell? This might of helped with some of the heat. Also to trim down xp did you use Nlite or just manually run into msconfig to snatch out services you didnt need? I thought about doing somethen like this with a stripped down Eee pc and using ubuntu that was stripped down. But none the less good work on the build.
