Chris_Top_Her
Contributor
- San Antonio, Texas
- '15 CX-5 Miata AWD
There is more than enough room for turbos behind the fog lights, it's tight but do able. I void turbos in the rear because it add a lot more things that can fail.
Correct PCV system would be off valve cover, to catch can, then to intake side of the turbo. This insures under boos the crank pressure does not build up higher than necessary.
Well I haven't welded my exhaust attachment yet (ordered a 2 bolt flange with a too small distance between the bolts). Just seemed like a hard place to route a very hot pipe towards the rear of the car. I'll take a look again, but the placement of the up pipe and down pipe is sketchy
