dannyboy said:Kim Tagert went to school at Penn State and was friends of a girl i dated who's a ***** of my exgirlfriend....not that i'm bitter or anything...
PMPJUICE25 said:They Are 6x9 's
Sir. SpeedALot said:I may be talking out of my ass, but there have been numerous post showing people using attachments so they can fit 6.5 speakers in the front door. I haven't actually removed them, so I can't confirm. Maybe the 5-door differs from the 4-door. This is giving me a headache... (braindead
so does the factory stereo run these ok?bluntman said:The stock ones are in fact oval 5x7/6x8, but with an available adapter plate you can install 6.5" speakers without a problem. I have a pair of Alpine SPX-117a 6.5" components in the front and a pair of 6.5" Alpine SPR-134a coaxials in the rear of my hatchback.
Also, be sure you get some sort of baffle or wrap the basket with duct tape so water won't short out your speakers. The factory speakers have a rain shield (half shield in fact) protecting them from this sort of thing.
brett_32i said:so does the factory stereo run these ok?
where did you place the tweaters?
what about rattles? or can you,live withit?
thanks
El Ropo said:Yes, the speakers are 5 x 7 / 6 x 8 standard ford issue. You can easily find speakers to fit the existing holes, or you could get nice quality seperates, and fit them in the factory location pretty easy. Here's what I did:
Infinity Reference Series 6.5" component set for the front, and 6.5" Coax for rear
1/4" MDF home made adapters for my speakers, painted flat black.
Component set mounted in factory location
A close up. It's hard to tell, but tweeter is angled up quite a bit, and imaging is fantastic.
The back door coaxials in their custom mount
And the 12" Crossfire sub in 1.2 ft3 MDF box. This sort of setup works really well in the hatch. I've got a binding post on the box, and banana clip connector, so it's quite easy to remove sub for lugging around cargo.
Why did you place the tweeters down there?
I like the box for your sub, where did you get it?
A box must be a certain size given the subs being used.krstofer said:You're smart.
I like the box for your sub, where did you get it? mine is too big.
Krs
I know, but it looks like the sub is a 10" which is what I have. I have a box meant to be ported, so I think it is bigger than necessary since I rather have a non-ported box.1sty said:A box must be a certain size given the subs being used.
MOck it up and then fill it with packing peanuts. Then put those peanuts in a gallon or 5 gallon bucket and use the gallon to liter conversion to determin what space you have.krstofer said:No, I think I will do whatever I want..(glare)
J/K I guess I should check the instructions. How do you know if you have the right size when making a fiberglass box? I am thinking of putting one either in the spare well or the jack space. I read you can be off 20% if you are using a sealed enclosure. but how do you measure it to begin with?
Krs
