Size of Oil Drain Plug
mmitsch
What size is the oil drain plug in the CX-5? A mechanic told me it's a torx head bold. Is that true? What size torx socket do I need. And, how do I access the plug? Is it easy? Lastly, is Catrol Edge with Titanium good oil for the car? I got 0W-20.
Let me know on the above.
Thanks!
Mike
Thanks!
Mike
It's an 8mm hex bit, not Torx. Lots of the info you're looking for has already been bounced around in a couple of the threads. Check out the one I'm linking below. Not sure what your budget is, but the Mazda branded 0W-20 full synthetic with moly received rave reviews in oil forums. I got a case for $96 shipped, or $8/quart. Good luck! It's actually a pretty easy oil change.
http://www.oilchangekits.com/lubricants/mazda-0w20-1-quart-893.html
http://www.mazdas247.com/forum/showthread.php?123814722-CX-5-Oil-Change-with-Filter
Thanks!
Thanks for the help!
