Sideview Camera
bchoi2
I'm trying to install Sideview Camera under Right Sidewiew Mirror. If I connect camera power to Right Turn Signal Bulb inside of Mirror, will this make camera blink? If yes, is there power source that gives constant power instead of blinking when right turn signal is on?
Probably in the blind spot warning system as it is on with the turn signal...
Yes, I believe that will make the camera work only when the signals are flashing. You have to run a rca signal wire so why not just extend the power wires just to play it safe?
I have already installed one, but I'm using the Aux input on my stereo. It's a couple of steps thing, not really convenient, but it works when it is really needed. I have hooked it up, to the backup signal.
It's a pain in the axx to fish through the cable, at the connector in the door's post. Yes, there is a big connector popped in there.
Next step, is to install one, at the front of the car.
If you hook it up to a constant power source, it may overheat. At least my Chinese camera, had a bulge in the cable(not sure what it was in there), but it got really hot, if I had a constant power ti it.
