Should I?
It'll definately be powering my fronts, but what I'm wondering is it more worth it to just get a four channel & power all the speakers?
get a 4 ch....not worth it....now if you had a sub box and say wanted to add some 8" or 6x9 for good mid....worth it
Thanks for your input. I'll probably wait, cuz no I don't wanna add anymore for the mids. And I reallt don't wanna run three amps later if I decide to power the rear doors. If my rear hatch area was not a necessity then I would.
1 amp for subs(mono) unless you're planning to run BIG speakers.
a 4 ch for the doors and i do know some have run 12" subs with 2 6x9 or 8" for good mids with with a seperate 2 ch amp so...
I'm running a single 12 with an Eclipse single channel now. I just liked that amp cuz it would match what I already have. They do have a 4 channel that matches, just not on sale.
eclipese make awesome 4 ch...i picked one up local for 100 (100wrms per ch)....check all yor local shops....right now they should be cleaning house of this years stock....just hunt around....and if you find a good deal on a good one....doesn't mater if they match cause if ya stick under the pas seat no one will know but you....unless you're ocd of course
(lol) naw, not ocd. Was planning to build a shelf on the back & displaying them, but if I find a good 4 channel then I'll probably be on it.
and you're gonna rerun wire all the way to the back...EKKK....i've seen it look good though....i have my sub amp and cap mounted to the box where i can pull it out if i need the space and i have the 4ch under the pass seat....i cut that floor heater and sealed it up with silicone
I don't think I'll need to run my cables to the back all over again. I ran 4 gauge all the way to the back already, so I"ll just ad a distribution block then run the next power wire from there.
i was talking about speaker wire there ya goose(chair)
