Sho's 2007 MS3
93 tune with Rob is done now. On to fill up with some e85 tonight once i burn off some more fuel. First map is ready to go!
Tuning is officially finished. Rob made my 93 map nice and tame (and safe) for autox. Its putting down an estimated 260whp/300tq.
E85 was finished last night. Making approximately 315/363, and it is an absolute joy to drive! I'll have to take it to smokeys and do a couple pulls on the dyno sometime and see what she really puts down to the ground
Yea my stock tune with stock everything was 255 whp, shouldn't the 93 tune have more HP? Also, what happened to the tune that you had by John?
Pardon my ignorance. Why the big power number difference?
E85 has knock resistance that 93 octane pump gas cannot provide. We can run a lot more timing advance on E85. I'm running 21psi with 9.5 timing on 93, and 21.5 psi with 18 timing on the E85 mix
I asked the tuner to keep things safe and controllable for autocross on the 93 map,Hence the low power. I only use it when autox or going where there's no E85.
As far as the other tune, I won't discuss that publicly lol
168 miles on a little more than half a tank? you sir are doing pretty good. I got 153 out of my last full tank. that one hurt haha
153 miles on a tank? That is just dumb! I'd have to fill up pretty much every day.
Will, I fill up every other day lol. Doesn't matter if it's normal pump gas or E85...but I drive a lot lol.
Some updates:
Stock suspension is back on the car, h&r coilovers will be sold, and then time to upgrade to something adjustable.
I also need a driver's side axle, but those Bastards are expensive!
This is why I could not own a modded MS3. I'm too cheap to be doing that s***. My last tank that included Pitt Race auto-x got me 28 mpg. Lowest I've ever had. Lulz.
Similar Threads and Articles
