Shifting in cold weather
Minnesota here. We were -21F the other morning and have been well below 0F for a number of days now. Yes, it is a bit sluggish and whiney at first, but never any hard or rough shifts. If anything it sort of oozes into the next gear until it warms up a bit. For what it's worth, I never warm up my CX-5. Just get in it and drive, the only warm up being the time it takes to put on my seatbelt. 175K trouble free miles.
I haven't seen the TSB for the software update that addresses this. I can see hard/rough shifts in cold weather; particularly if the trans fluid is not up to operating temperature. But it seems there's more to cold temps and shifting quality that the update addresses.
I was just showing how your own comment went on to say that it is normal for you. After saying that it wasn't :D
noooo I never said it was normal.. I just said it happens. There is a difference, lol.
Thanks! I wasn't familiar with reprogramming. So hard shifting in cold weather is more of a bug?
The first-gen Mazda Miata was known for harder shifts in weather that got into the twenties on down, at least until it was well warmed-up, particularly in the 1-2 and 2-1 gears. Some people have had better luck with certain types of fluid for the transmission, ones that are a bit slicker and a bit more capable in cold weather. (For my old first-gen Miata, @ 30Kmi intervals I did Redline MT90 in the trans, Redline 75w90 GL-5 gear oil in the diff, RedLine MTL in the shifter turret. Helped to keep minor 'notchy' shift behaviors to a bare minimum.)
In my own winter experiences with the CX-5, it's on the factory-approved FZ type transm fluid. I don't go more than ~45Kmi on the drive train fluids (transm, xfer case, diff). As well, I often do the relearn/reprogramming procedure for the transm, every two or three weeks, generally. And I generally wait until the car's warmed up decently, before I begin getting frisky with the throttle. All of which ought to help, assuming the transm doesn't have a gear problem, which any given car might well have a bit of. As fairly bomb-proof as these seem to be, there's going to be an occasional unit that has issues, or premature wear not typical of the line.
I suppose some might call all that a "bug". IMO, it's mechanical. And it involves metal-to-metal wear. So it's subject to whatever minor manufacturing tolerance a given unit might have along with a given unit's wear patterns. Which is going to vary from car to car, a bit. Including some feeling a bit rougher until warmed-up.
That all being said, in temps in the single-digits and below, I have noticed the 2016 CX-5 transmission to be a bit less 'spirited' and smooth until things warm up fully. In my case, it's fairly smooth then, almost buttery smooth.
Not sure how much different the tranny is on a 2015 compared to 2023 but even at -40 mine doesn't really shift any different. If anything it might shift a little later in the revs until the tranny fluid warms up but still smooth shifts.
Well, let's see how it shifts 300k km later. Lol.
Today was -20c (-4f), according to the vehicle, and I did not notice any funny shifting. It was a similar temp here last week, and it did then.
To OP or others having this issue
Ensure fluid level is good
Figure out if Mazda will reprogram the trans.
Use only the FZ fluid. I heard that different colour atfs can cause this.
There is a TSB on a 2-3 flare and hard shift. It requires a reprogramming for the trans. Mine did that from day one when cold, the reprogramming totally fixed it. Free under warranty.
Thanks for that. I guess. Was hoping just normal and not a dealer visit - scheduled for tomorrow. . .will report back.
Dealer scheduled me yesterday aftenoon. Couldn’t replicate the hard shift with warmed up transmission, but did the reprogramming procedure. I made the warranty cutoff by about a month so no charge. Out the door in 35 min. The test was this am at 7F and great to feel it shift smooth 2-3 as in other gears. Same again this afternoon with cold transmission. Big thanks to YosD for TSB heads-up and all for comments here!
