shifter linkage bushings
faridk89
02 p5, silver
hey i need to get new linkage bushings, mazda wants 180 plus tax to change it....no thanks lol, any idea where i can get a hand on them online? thanks!
If you used the stock hardware it should fit, it says on the site to upgrade the bushings when you get a short shifter.
Lol I can't rember if I reused the stock hardwre or if the twm came with bushings
i think i might end up getting the linkage bushings from mazda dealership
don't do it.... the stock ones are plastic pieces of crap....
i was able to use one pair and installed it on the transmission side... it's a night and day difference... tighter shifter, crisp shifting... it feels awesome...
oh and it doesn't work on the TWM SS... the TWM SS has bearing instead on the bottom of the shifter... probably way better than bushings i suppose
You can still use the Corksport bushings with the TWM, just not where the shifter connects to the linkage. You can use them in the front where the linkage connects to the transmission. So basically you'll have a couple extra bronzeoil bushings with the corksport/twm combo.
yeah i ended up getting upper and lower for 7 bucks from mazda :( lol, i was wondering would the protege speed ones work with the p5?
