on the transmission its the bar that comes from under the shifter to the transmission and isn't supposed to move the factory ones are black in color can't miss it.
the shaft that these shifter linkages connect to going into trans is leaking oil from inside the boot that covers shaft going into trans... What is wrong with this? A seal? Is it an easy fix or the whole trans needs rebuilt
