I have a 2002 Mazda Protege 5 and I am experiencing the same thing with my car last Friday. It didn't start up at all. Until I went to AutoZone and had gotten this AutoScanner for it. Plug em in, cranked the car up it started! When the past Saturday came through, it went well. But, when Sunday came around it wasn't all that bad. Until TODAY, when my brother had switched it out with new spark plugs and wires, it wasn't the problem. The engine would really shake, it would seemed as if the car will stalled on me when I'm a traffic light. The autoscanner read RANDOM MISFIRE, SYSTEM LEAN and some other things with THRESHOLD. I don't know guys. The car also had 155,XXX on it. I ordered an O2 Sensor, expecting to have that in a few days or by next week. The CEL sometimes blinks and then it would stay on there. Its really giving me a headache right now. CAN SOMEONE PLEEEEEASE HELP ME OUT HERE??
Anyone else realize this thread is a year old...I'm guessing he got it fixed by now...
Yes, it has been resurrected from the dead. Bwahahaha!
Sounds like the EVAP Solenoid is stuck open.
I had this same problem with my 3. I had read that the EVAP problem is very common on these mazda's, so instead of going through the multiple visits to the dealer i figured it could be fixed. If you take off the evap solenoid and look down in it, you will see a little screw slot. I screwed this out as far as it would go and put some penetrating oil into it and blew it out with an air hose. Then I tightened back up pretty tight. Reset my Engine light by disconnecting the battery. No check engine light now. Also my car was missing when at an idle caused by the evap solenoid being stuck open. This fixed my check engine light and the miss.
Hope this helps!!!!
Yes, take it back to the same mechanic if they are planning to re-evaluate it without charging another diagnostic fee. When they read the OBD codes, compare it with the previous read-out results, and post them here. I'm curious if the same trouble codes have returned or if it's a whole new set of codes.
Hello, btw. This is my first posting. I've been just lurking on here.
