Server Update!
Nutari said:
(pissed) :bs: (pissed) (ughdance) test
so far, everything is workign in Firefox as far as replies go
file uploads seem to be hanging...
(first)
  • ditto ditto ditto ditto ditto ditto ditto
What happened? It was like mazdaforum 9/11 for 2 days.Glad it's back up...Noticed attached files not showing thumbnailsHad a tough time inserting a pic in a post using IE 6.0
WTF. I have FireFox 1.5.0.1 and when I check for updates it says there are none. I exited and restarted to be safe. I have a box that looks like the WYSIWYG but the icons do nothing.
If I inspect the JavaScript Console I see the following...
Error: vB_Editor is not defined
Source File: http://www.msprotege.com/forum/clientscript/vbulletin_textedit.js
Line: 2894
Error: vbphrase is not defined
Source File: http://www.msprotege.com/forum/showthread.php?p=2385057&posted=1#post2385057
Line: 2009
Error: AJAX_Compatible is not defined
Source File: http://www.msprotege.com/forum/clientscript/vbulletin_quick_edit.js
Line: 19
Line: 2194
when you try to give rep points and you click on the little icon it sends you back to the top of the page, anyone else have this problem?
Line: 2894
Line: 2009
Line: 19
Line: 2194
Ok now I'm checking on my laptop running XP SP2:
Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1
(ughdance) (ughdance) (ughdance) (ughdance) yup everything is still working.
(poke)
Actually, when I click to insert emoticons it scrolls back to the top of the text box, but it was probably doing that before (the message in the box just wasn't long enough).
(first)(first)(first)(first) everything is fine if I use the editor that shows formatting (click the switch editor mode in the top right).
Actually I don't have any extensions running right now though because the Firefox 2 alpha I was trying out disabled all of them. Running any extensions on your install of firefox?
Edit: the comment in the first script that was giving you an error right above that block of code says:
vbulletin_textedit.js said:
* Save editor contents to textarea so if we hit back / forward its not lost
* Only appears to work with Firefox at the moment
Oh my I think I just saw an amazing new feature. When using the quick reply box it doesn't reload the whole page to show the new post. Oh, the beauty of javascript/ajax.
Ok...so I exited all firefox and all I.E. windows, then restarted FireFox and it is apparently working now.
ok so I just checked updates, closed and restarted Firefox. My problems are as follows:
I have to type "br /" w/brackets to separate lines. Otherwise it loops it all together.
Formatting text options do not work - can't click on Bold, Italic, etc...
I am unable to upload attachments. There is no "manage attachments" button.
As a mod, I used to be able to edit posts in FS threads. I only did this once when someone was a total jerk, but still...
I've tried it with Firefox in Linux, Windows XP SP2, and Mac OS X without any problems currently. Maybe the Firefox process is still running even when you close it, it has happened to me on Windows machines before.
Other than that I really don't know though.
hmm, I am on Win XP x64, so perhaps that's why?
edit: I am now trying 64-bit IE... so far those problems are fixed... ok apparently it adds the spaces, I can change fonts, add attachments, AND edit posts. Maybe I'll have to start using IE again. ugh.
Zverg, I edited one of your posts and signed it so you know I did. Just added the word "test".
ok so it seems that using winxp x64 and firefox is not a good combo for viewing this site :(
Also having problems with threads not marking as "read" properly.
justanotheradikt said:
mine still reloads
Mine doesn't on my desktop running XP SP2 but does on my laptop running.. XP SP2, both with the exact same version of Firefox too.
Zath, what post did you edit? I looked back a couple pages and didn't notice anything :(
It worked though? Are you running an optimized build of Firefox for 64-bit systems or just the standard windows 2k/XP build?
Standard 2k/xp build. Unfortunately, I can't find a lot of "optimized" stuff :(
The editing was in one of your recent posts in a FS thread. If you can't notice it, then I guess I did a good job, eh? :)
Oh right, you aren't a mod in this forum. Damn now I'll have to go hunt it down.
link me! :)
