Check the injector plugs.. Make sure one or two didn't get knocked loose.
checked the plugs and they are tight. should i maybe pull the injectors and test them?
What about the camshaft position sensor? Does anyone know how to test it? my car has many symptoms of a failing camshaft sensor.Shouldn't be necessary, they were working before.
My advice is to take it to a mechanic. There's nothing more I can suggest over the Internet, and you've checked the easy stuff.
I actually took the plugs out and they aren't wet at all. The engine starts fine I just doesn't like to idle and it sound terrible. The sound seems to be from the left side of the engine so originally I had thought timing belt but I checked that and it's fine. I get some pics. Tested the mad with multimeter and seems to be fine.Is there any oil on the plugs? When you checked the plugs did you actually remove them or just remove the coils and boots? Do you have any pictures of the engine that we could look at? pictures of the intake, valve cover, and at the throttlebody? Is the maf plugged back in?
Also forgot to mention I replaced the camshaft position sensor with a used one (low km) and nothing changed.I actually took the plugs out and they aren't wet at all. The engine starts fine I just doesn't like to idle and it sound terrible. The sound seems to be from the left side of the engine so originally I had thought timing belt but I checked that and it's fine. I get some pics. Tested the mad with multimeter and seems to be fine.
whoops that won't work lol. ignore thatcontent://media/external/file/62748
