rubbing depends on many things, but bottom line, if you are lowered with 7" wide tires, you are probably going to rub...sorry
i basically have the same set up as you and i can get some mean rubbing going on in the rear mostly, usually only if there is lots of stuff in the boot or two or more adults [sized] people...
