roll fenders or more negative camber
bova80
2007 Mazdaspeed6 GT
ha so i put on 8" rims with a 48+ offset and they are real close to my fender when ever that spring compresses (aka going up my driveway). i don't think it will rub but i think a little more negative camber will give some more room. negative camber is set to -1.33 degrees right now
unless I am missing some advantage in messing with your alignment for clearance issues, I see no reason not to just roll the fenders....
Rolling the fenders should take care of the issue. BTW what are you dropped on? I plan on ordering a set of p1's in that size and running a set of 225/40's on them, but your pic (assuming it's under compression for illustration purposes) is making me a little uncomfortable with that choice.
i have 225/45 and i'm running the rpm street springs. this is not my ride height though, this is just when i go up my driveway.
