Road Noise
Hi,
Not sure where to post this.
I get a lot of road noise, on very smooth asphalt it is OK, but on concrete or textured asphalt the road noise is terrible.
Im guessing the tires are the main culprit any recommendations on a tire that would help minimise the road surface tire noise?
I dont really want to have to ripout the interior and sound deaden the whole car.
One solution is to install a really loud intake and exhaust system to drown out the tire noise.
Or just crank up the tunes.
I don't think many of us bought ms3's looking for a quiet ride.
Sure, look at some vehicle models that are meant to have very quiet rides (Lincoln, Lexus) and pick up some similar tires.
Unfortunately, you will more than likely completely destroy the performance of the MS3, since cars that are meant to be quiet aren't meant to go fast :)
I also find that the road noise can get wearing for long trips on the wrong kind of pavement. Turning up the stereo or making the exhaust louder isn't a good fix as the extra noise will be even more tiring. I use my car both for sporty back road driving and on longer trips to bike races. When you're already beat from a 112 mile race you don't need 7 hours of loud noise on the trip back.
When I wear out the stock tires I'll pay attention to road noise as a factor in choosing a new set. I don't know how much road noise I'll be able to get rid of without compromising handling.
It seems like adding some sound deadening would help with the road noise and with the 3k rpm trailing throttle drone from the exhaust.
The MS3 may be the quietest car I've ever driven, and that's part of the charm!! I've had beaters and slow loud fart-can cars all my life.... the MS3 is the best of all worlds. It's quiet when desired and fast when my foot gets heavy.
well, cant expect 20k car to do everything.
Probably m3 would have been better suited for your need.
There are certain tires on the market that are specifically designed for low road noise. Unfortunately, getting them in the stock size is not possible so if you want to do that, you'll be going with a different tire size. A 17" wheel/tire combo would also go a long way to silencing the car, especially if you get one of said engineered-quiet tires for them.
Beyond that, most interior road noise comes from the rear wheel wells so you wouldn't really have to rip up the whole car to get it relatively quiet.
All right guys. He asks a legitimate question in good faith. Either answer it like you know the answer or don't post at all.
FFF,
I have not tried this myself as I don't mind a little road/tire noise, but have read that some loosen the inner fender wells (plastic) and use spray in foam on the underside of it to help quiet road noise. It's supposed to be a trick used on Focus's which are known to be VERY noisy in the wheel/tire department.
Thanks for your comments, constructive or otherwise.
Im going to see if I can detect where the majority of the sound is coming from.
It is definately road/tire noise, the exhaust noise I can deal with, Im going to try to soundproof the easiest areas first, where I dont have to take the interior out, ie accessible hatch area, possibly wheel wells, maybe firewall.
Quieter tires are definately in my future, not sure if I should replace them now and sell these nearly new or just let them wear out.
Of the tires available in the stock size does anyone have any suggestions/recommendations of tires that they have used which generate less noise than the stockers.
Real suggestions only please, not buy another car, grow a dick, drown the noise with some other noise, or wear earplugs. I already thought of those ;-p
Thanks in advance
Do you know what product they use?
Would the foam trap moisture and cause possible corrosion down the road?
You think foam would be better or a stick on product like damplifier?
I see you have a straight 3 I drove it too and it was a fair bit quieter, I dont know if they use more soundproofing in the 3 or if it is just the change in wheel and tire size tire type and suspension stiffer that causes the extra noise.
There is nothing in the stock size that will be significantly quieter except maybe the Dunlop SP 5000 or the Kumho SPT.
Yes I was just lookng at the tire rack website and thought the Kumho SPT might be quieter just looking at the reviews, its a shame you cant test drive new tires. Guess I will wait for these to wear out. I dont suppose there is much of a market for tires with 300 miles on them?
In that case some soundproofing looks in order, but I am not going to rip the interior out of my brand new car, just do the easly accessible stuff first, hatch area, wheel wells, possibly firewall, hopefully that will reduce it enough.
i just bought the good year eagle F1's and think they are significantly quieter then the kumho's i had before... i have a mazda3 but i have 18x7.5 rims on it.... so take it for what its worth but i am loving more grip and less noise from these tires.
I see you have a straight 3. I drove it too and it was a fair bit quieter, I dont know if they use more soundproofing in the 3 or if it is just the change in wheel and tire size tire type and suspension stiffer that causes the extra noise.
1) I would say, ummmm, nearly anything from the Big Orange (or equivalent) designed for use in the home around windows and doors, though I prefer the DAP products myself.
2) Plastic, as far as I know, doesn't corrode. :)
3) Since the object seems to be to eliminate resonance, I don't think it would matter, though spray foam would certainly be cheaper, sq.ft by sq.ft.
4) Again, I doubt that the NA 3's have more insulation since the weight difference of an MS is about equivalent to what; a) turbo chargers and it's related hardware, b) an LSD, c) a reinforced chassis, d) bigger brakes, and e) rather heavy (imo) 18" wheels weigh in at.
5) And how is it that you were driving MY car w/o my permission?
The Kumho ASX's I am running now are a bargain imo, and of the 3 sets I've run so far (GY RS-A's, Falken ZE-512's,) are the widest (225/45,) the smoothest riding and the quietest of them all.
Oh OK, I misunderstood (doh), I thought you meant remove the plastic cover and line the underside of the metal wheel well with foam then replace the cover.
Right now Im just weighing options, I am going to do something though, just trying to decide what will have the best effect with the least amount of effort.
Just messin' w/ya' fff.
Do you hang glide or fly sail planes?
Airline pilot and skydiver, just added an avatar.
I used to fly sailplanes 20 years ago, have taken some hang gliding lessons off a large sand dune but nothing serious in that dept.
Im in these skydiving vids a few times if anyone wants to check them out. My jumpsuit has a white body with red and yellow arms just like in the Avatar.....Enjoy!:
http://www.youtube.com/v/jvQ1nu9AudM
http://www.youtube.com/v/C4nm0rN4X3s
That's some intense stuff there. Well made vid too.
I used to have a pipe-dream yrs ago when I was younger of learning how to fly a sailplane, but I don't think I could ever throw myself out of a moving plane at 6-10k ft.
What airline? Do you ever fly to Newark or ABE?
Do it. I'm afraid of heights, but my woman took me skydiving for my birthday last year, and looking back I would've regretted not doing it at least once in my life. Jumped out at 13,000 feet, deployed the 'chute at 6,000. But those first 7,000 feet, you'll never experience anything like it.
