but will they tuck being that wide?Natey said:IMHO, some 18x7.5's wrapped in 215/40's looks and drives (thumb) killer!
usually it's the lower offset that causes problems, not higher - unless it's really high, and yes, spacers would help in that situation.trbomp5 said:1st question though is, the lower the offset the more the tires will stick out correct? So if i get one too high, pushing them in farther, I can just then mill out some spacers to put them exactly where i need them.
That looks really good. What is the offset on your rims? And do you have room to move them in more or are you about rubbing the strut?Natey said:Not tucked...18" tires cost too much for me to bust out that kind of camber.Pretty damn low, though.
17X7 +45 should workLiMPiNg said:I am running a P5 and looking to upgrade the rims/tires. The car is not lowered yet, but I plan to go with the Eibach Pro when I do. I am looking at some 17x7 with 45mm offset, with 205/45/17 . Would this package work for fitment? Could I even go to a 215/40/17?
