Rishie's FITMENT RECIPE
I suppose all the changes I've made to my car, 3 sets of different tires, 2 different sets of wheels, and 3 different suspensions doesn't matter.
oh well, I dont care anymore. I'm just trying to help him from making a costly mistake.
yes it will work, but when you hit bumps with weight or people in the car it will rub the fender. unless you get camber correction bolts and kill your tread in 10k-15k miles.
Abqcivic said:
But it's the same to me as everyone running 17-18" wheels. No performance gain. Most of the time it kills your gearing. I'd much rather have a wider tire patch than a taller tire.
a wider tire patch, is great, but the wheel must get wider with it to improve handling. I would bet that youd get better numbers on a 7" wheel with a 205 or 215 tire than a 225.
ayways, good luck with your choice.
and you believe that your monstrous (and probably heavy ass) tires are going to be much more noticable over my stock weight 17s with 215/40 series tires? i dont think so, chief. and it will look ridiculous, assuming it even works, and then is noticable.
RyanJayG said:
how about this, look at my car... its in my sig. I AM VERY dropped, and I am tucked at all 4 corners. I have 215, 35 x 18 tires, 7.5" width, +45 offset. and I cannot fit more than 5 pieces of paper between my fender and my tire. and I have even rolled my fender.
now tell me how your 225 tire will fit with 1 mm higher offset than what I have, not to mention the fact you will have a taller, slightly more flexable sidewall (read: expanding)
I like your sig, nice ride but you proved my point to a tee. Your 18x7.5 45mm offset is the exact same outside measurments as the the setup i'm planning on doing. The only difference is the tire and width. Your 5.52" inside and 1.98" outside. SAME OUTSIDE. With having a less aggresive drop the and a higher spring rate solves the problem.
haha, higher spring rate than I have? not unless you hate your kidneys.
the 7" wide 40mm is about 1 mm further from the fender but you are forgetting the tire is 5mm wider on both the inside and the outside. so you would be effectively 4mm further to the outside on the outside edge than I am. 1 more mm and I would hit the fender.
less agressive drop will help you to a point, but like I said, you'll be fine untill you put passengers in the rear or something heavy in the trunk. hit a bump and oyu will rub.
Your 17" wheels
OEM wheel 17-19lbs
Tires 215/45/17 23-25lbs
Total 42-47lbs
My setup
16" roya slips 13.5lbs
225/45/16 25-27lbs
Total 38-42lbs
Anything else??
your math is incorrect. i believe my total weight is 29 pounds. nice try. notice i said stock WEIGHT 17s, meaning the whole package. total my weight is 28lbs or 29lbs i forget which, with tires.
furthermore, on your setup, you wont notice a LICK of difference performace wise. garuntee it. and lastly, will a ******* 225 even with on a 16in rim?
What are we arguing about here? I see some good math being done here, haven't taken the time to read most of it but I hope this is being constructive to the thread. I would hate for the inexperienced end user to vear from the guide. This guide is based on physical fitments that we had done in the early stages of the 3rd gen wagon and sedan.
I don't know if this has any relevance to the argument. But I will repeat some basic information that should be throughout this thread. I will list a few fitments quickly with regards to some speed reading I did above.
The sedan has about 3mm more front spacing than the wagon. I'm sure you're all aware of that by now. Now the guide is based on an unmodified fender. There is a good amount of fender lip on the P5 near the front and rear of the "rear" fender wells. This however does become very thin at the center of its arc, therefore in my eyes viewing it as a huge liability i.e. cracked paint, etc...
From this my physical work came to the conclusion, with most brand tires, that a 17x7 +42 was a good tolerance for a 215/40/17 on the NA models sedans. I felt that this tire provided maximum contact patch in near stock diameter and available in most popular and unpopular tire brands. Now for a wagon that became a +45 on the 7" width. Keep in mind tire flex as well, also the way a tire may stretch on a specified width will also change other dependent values.
For a 7.5" wide, +45 on sedan, and +48 on the wagon. Retaining the 215/40/17. With the wagon we were able to run a 205/40/17 on a 7" +42, but to me this was not ideal. I did not like the asthetics nor the deviation from the "ideal".
If one wanted to run a 225 on a 17" wheel the closest to stock NA diameter would be a 225/40/17. Now the problem with this tire size is that it's extremely limited in selection. One is the Nitto NT555, I've had them, the other is the Wanli, decent and cheap. Neither of the two in my opion are extremely performance oriented. Trust me I've tested both. This is why I move to the 215/40 or 215/45.
I have a wagon and since it's boosted I've opted to run a 215/45/17 to assist in my gearing. I have all 7.5" +48 wheels. With this tire size the only area I "grabbed" was the front portion of the rear fender well. Where it comes down towards the side skirt.
The world challenge cars ran a 225/45 T1S with a 17x8 +45. The backspacing isn't the issue with our cars as much as it is the front spacing. These cars had heavily modified fenders.
With regards to the majority of Macpherson strut style suspensions the "wheel" will camber in more upon compression of the damper. I have not needed to take any of this into consideration since we decided to say "Screw it, let's just buy a bunch of different wheels/tires and test them out." We ran touge, messed up streets, downtown areas, etc.... Based on that we were able to determine what the "safest tolerances" are.
Anyways, if you want to email me sales@autornd.com I can try to answer any questions based on my personal experiences with the 3G chasis.
Later guys. Don't forget we can always start a wheel fitment debate thread. Let's try to keep this clean. I know there are guys here that have continually been supportive of the community in my consistent absence. I would hope that they are very highly respected. I do quite enjoy the mathematics being displayed. It makes me happy to know that there are people who find this easy. The only problem is that these aren't ideal physical situations. There are many unaccounted for variables. I do see some serious detail but honestly we can argue about math all day long. It all comes down to simple testing and survey. Take an average and see where the we all fall. There will also be minor variations from chasis to chasis. No two are identical. Shoot every protege5 will have less front spacing on one of the rear fenders than the other, therefore causing it to rub.
Peace, Rishie
ARD,
Like I said, not trying to be an ass but some of the info here is misleading. I understand to test and tune is the only real way to get defiant results. As soon as I said I want to run 225 width tires the pissing contest started. Have not seen anyone with hard evidence and help till you arrived but tolerances change dramatically from a 16x7 to a 17x7.5 or 17x8 that you are talking about. Thanks
Ryan,
Daily driver, 94civic coupe, custom G/C 7" springs, 450 fronts, 550 rears, Koni yellow with a re-valve. 215/45/16 azenis, rota slip's 16x7 40mm offset. Close to a 3" drop. -1.75 camber front, -1 camber rear. No rubs. Your TeinSS are rated at 336 fronts, 280 rears. The reason you car ride as rough as it does is the lack of sidewall on the tire. Almost like running on the outside shell of the wheel itself. Now I know hub location and wheel well are different for a P5 but there is more room under the P5. The only thing to factor in is the strut and spring location, but if nothing is added to the inside of the wheel, theres nothing more to say.
Matt,
Have not learned anything YET?? There is no production tire; 17" size those weights less than 18lbs. My P5 16x6 wheels weight close to 15lbs each, wheel alone. Now you add the extra material for the 17" size but it weights less, I don't think so. With your math, tires weights 18lbs, your OEM wheel weights 11lbs. DAMN; I'll change my bolt pattern on every car I own to Mazda to take advantage of an 11lbs OEM wheel. My 13.5lbs rota slip's 16x7 and 215/45/16 weight 37lbs.
Apologize if I got under everyone's skin, but I won't back down if the basic knowledge of performance gain is turned down.
all I can say is buy those tires and wheels, and prove me right.
we try to help, no less than 4 people have told you it will not fit, but you continue to insist that your math is superior to everyone's experience.
go ahead, buy them. I will never again clutter this thread with information attempting to help those that have questions.
Ryan, I think you've been very helpful here and would hate to see you go.
Boston,
Those wheels are too wide no matter what offset you get. hehe.
Rishie
im still on the fence as to whether or not my 17X7 (+42mm) will fit the p5 with 205/40/17 tires. im planning on getting the espelir springs in the very near future (waiting on tax return), so i will be lowered. rishee, i know you said its close depending on what tire i get, but which tire would you recommend? i have many that i have considered, but have yet to make the choice. i am leaning towards the yokohama avs es100's though.
I think that since you've selected a 205 tire you should have no trouble, and iirc the es100's aren't a freakishly wide tire for its rating.
57Pro can be had in a custom offset if special ordered. I am confident I can get those wheels for your car in the right fitment. Please email me sales@autornd.com
60-90 day wait. Patience is a virtue.
Rishie
thanks.
what are some tires that are 'freakishly wide?'
yea i just wana say thankx rishie everything on mine fits great with no rubbing, and fills nicely
17" rota subzeros sittin on
tokico shocks with espelir springs
protejay5 said:
thanks.
BFGoodrich KDW2's are freakishly wide for their size... but I've only compared 215,35-18's to 2 other brands and found them to be quite a bit wider than "rated"
.. I put a thread about this in the MSP section, but figured I'd try this thread, too.
A friend of a friend is willin' to sell me a set of 18" x 7.5" Konig Holes for a really good price -- I'm not positive of the offset of those kinda wheels, and I tried to research to find out, but came up empty-handed. The best info I could get is that I know the same wheels ( Konig Holes) come in 17" x 7.5" with a 45mm offset. Based off of that, and if anyone else has the 18" x 7.5" version of these wheels .. will they fit on the MSP? And if so, what size tire will I have to run? I'm still on the stock MSP suspension, so will I be able to use a 215/40/18 tire? Or am I gonna have to go with a 205/35/18 size?
Thanks for the help!
