bags- expenisve, but can drop when you want em. not that good of handling (compared to coilovers) and you have to have a compressor in the trunk.
coilovers all the way,
I'm buying one tomorrowjust needs to be painted
coilovers-relatively cheap. (blown set on here for 200$) can fine tune your setup, better handling, and stiffer.
badass and nah i dontI'm buying one tomorrow, I hope you don't mind all my posting in your thread Rico lol
old way of thinking..
the new coil over bags that ksport makes uses the same struts you have on your car, but instead of a spring they use an airbag. They have the same dampening adjustments and you can set the min height same as the coilovers. The handling in the car is the same as the coilovers you just have the ability to adjust your height on the fly. When i need to replace my Coilovers i will be buying the Ksport kit so i can have the same handling that Im used to know with teh ability to raise the car when needed or put it on the ground for shows..
SS gotchya, you called it out didn't you aj?he said they were tein basics, but were labeled tein superstreets
sweet. I know Tein and K sport works well with the P5no, but superstreets are actually better than the basics.
