Rhino Ramps
Well, theoretically I'm sure they're strong enough. My question is what happens if that plastic deforms even in the slightest manor or had even the slightest deformation caused during manufacturing? Failure. You would hope that they test them at the factory, but I'm sure they're made in China. Chinese companies have such little regard for the end user that they put a toxic chemical into baby formula to raise the apparent protein levels. Remember the Melamine debacle? They don't give a f***. Regardless, defects occur even in countries with responsible, moral vendors producing our products.
This means you have NOT use them? Hate to burst your bubble but these ramps are made in the good ol US of A.
Problem is common sense is not very common anymore. As with ramps and EVERYTHING else in this world, there will be idiots who misuse things (or simply dont understand how to use) and get hurt. There are stories of jacks failing as well so that point is moot. People try to use then on NON flat surfaces, or potentially abuse them by leaving it outside during the year respect mother nature, shes a fierce one.
We can and should only give feedback from our own experiences and not rely on internet stories b/c there is a lot of history behind them untold. I stand by my 12000 lbs GWV rhino ramps (but realize they will fail over time as the material will surly wear out). Btw, are you referring to the rhino ramp incident on BITOG forum? Funny b/c the OP got replacement ramps and went back to using them!
Burst my bubble? Calm down forum warrior. Actually I know they can be purchased at WalMart so I assumed they were Chinese since WalMart is out to destroy America. All it means is that there is most likely better inspection.
I'm referring to constant garage accidents that I read about locally. My tangential discussion of safety actually has nothing to do with Rhino in particular. Ramps in general.
LOL Robo. I did not mean it in that context. I was referring to bursting you bubble in how you think everything is unsafe and everyone is out to destroy you (or America as you put it).
I checked out the Rhino ramps you mentioned while at Walmart yesterday. Now I understand how we are talking about two COMPLETELY different things! The Walmart Rhino ramps do carry Made in the US and are the 8K GVW version and it looks FLIMSY!! I would NOT trust those ramps either nor would I recommend them. I highly recommend you to check out the 12K version. The material/compound depth looks to me like it is almost twice as thick!
To add a bit more clarity, my brother, who is ME by trade but does not care much about cars, bought the ramps for oil changes. I was also (and still am for certain work) a firm believer of jacks but have since converted for small/quick duties. If I have to do undercarriage work I will still use jacks (more height) but the 12K Rhino ramps are great.
I think RAMPS are unsafe, not everything, and I think WALMART is out to destroy America, not everyone, just for the record. But, I know about Walmart's practices overseas to ensure that the get the cheapest stuff and force their customers to weed out the defective products. There's a reason it's cheaper. I hate Walmart. Always have and always will. It's the pinnacle of embodiment for what is wrong with America. I consider people who shop there to be traitors, or inexcusably ignorant. I'm sure that offends someone, but I don't care. I digress.
To sort of get back on track here, I've never been a fan of Rhino or other branded ramps, primarily because of the steep angle. Thus, I went w/do-it-yourself wooden ramps, using 2x10's, deck screws and carpenter's glue; it allows for a gentler incline, the ramps don't slide and there is no chance of collapse. With mounted wooden stops at the front of the ramps, chock blocks at the rear wheels, A/T left in "P" and the e-brake on, the car won't move while I'm under it.
I believe I purchased all the lumber for <$40 at Home Depot, though 2" deck screws will run another $5/box (I didn't need any, as I have all sorts of leftover fasteners from other projects). Anyway, the only negative about building such ramps is the storage issue; mine are about six and a half feet long, so it obviously takes up more garage space than traditional metal or plastic ramps. It would be my suggestion though to anybody trying this to move up to 2x12's...they're not much more expensive and they give you a wider contact pad; that said, 2x10's are perfectly fine for my 5, Vibe, Ranger & Mustang.
If anybody's interested, here's a link to the instructions I used: Make your own ramps.
Jeff
PS: If anybody would like photos of my 5 on ramps, let me know...I'll post some to give you an idea of clearance, etc.
(squinty)Coincidence? Perhaps... Offended? Heck no! Where else can you get Motorcraft Syn blend 5-20 for ~$3 a bottle! Actually I hate Walmart too but not for the reasons you stated. FYI, one of the many reasons why Walmart is so successful is there homegrown business information solution that allows them to see/forecast what/how things sell. One of the best solutions out there and ensure they are ontop of suppliers and the market. They command things and you can’t blame them for playing the game right. They started out very small as a mom and pop shop. Don’t hate the player, hate the game, in this case free market/capitalism. (usa)Hate that and you hate America, mister. Yanking your chain.
Back to ramp:
@ Jeff - those ramps look HUGH (size and weight)! I'm sure you've seen some well executed ones. I may make one sometime in the future. Shouldn't be too difficult but would need proper cutting tools. Measure lowest point of bumper, line to lowest point of wheel to get incline%. Layer wood and cut to size. I've also read some put a small wheell on the end to help move it since a stack of wood is naturally going to be heavy. Should be a fun project.
Wow. All Rhino Ramps are made in the USA. I trust them over any pair of steel made in China jack stands any day.
Rhino Ramps are safe when used correctly. Period.
I have two sets. The first was the 8000 (4K lbs per pair). Used them for years with my VUE, Accord and Lancer. No issues what-so-ever. Then there was an incredible deal for the 12000 (6K lbs per pair) at Autozone, something like $30. So I bought them. I've used them with my 5 for the first transmission fluid change. Plan on doing two more before the winter hits so I have all fresh fluid circulating.
Back to ramp:
Wow, missed this. I definitely went over the line attacking people who shop at Walmart, but only because people don't know just how bad they are. I'm sorry for saying such a bad thing, but my god I hate that place with a passion.
Let me explain. Industrial engineers design an assembly process, and much like an electronic circuit, it has tolerances for each stage that add up from beginning to end. At a cheap Chinese factory they will have a range of tolerances for what is acceptable and what is not with regard to the finished product. For vendor X, say Sears, the acceptable range is +/- .5% for some random plastic piece of crap. For Walmart, the range is different. When a part comes out where the assembly line has lost its precision, they stick the crap in the back and slap a "Walmart" sign on it. Then you come along, buy the cheap crap, and manually filter the acceptable, working products from the broken ones. They know many will buy broken junk, but they don't care. You get to bring it back, which makes you happy(sadly) and they filter all the garbage out for the manufacturer. In return, Walmart gets it cheaper than Sears. Originally this started with Walmart forcing companies to allow such a shady practice as a condition of carrying their products. They are heavy-handed crooks. See how that works? I know an industrial designer who works in Asia and he said it's common knowledge that "discount" stores do this. Walmart started it and is the master. Often they will even own the factory and get more of the profit from the company who designed the product. What they do is blatantly illegal in my opinion and absolutely not American unless capitalism is greed.
Additionally, I have bought a stereo from Sam's Club that, you guessed it, broke immediately. I opened it up to see what was going on because I was in electrical engineering school at the time and gave a crap about fixing their garbage instead of shoving it up their ass. Opened it up and it had a "refurbish certification by: xxx" tag inside. It was sold as new. I was ignorant enough to believe it was an anomaly. Then, I bought a DVD from MallWart. The DVD player quit working immediately as well. I opened the tray to see if the gears were intact and there was dust where the thing had sat open in a factory waiting to be repaired. Below the tray was a tray where a hand had wiped across to remove the dust, leaving it in the corners. Clearly the device was returned and sat around in some nasty, filthy Chinese factory for who know how long. I will never buy anything ever from that dishonest, corrupt piece of crap for a company.
That is fact and that is why I hate Walmart. They are what is wrong with America: unbounded, unrepentant greed. I disagree with anyone who does not see it the same. My father and grandfather taught me that Capitalism is the freedom to trade and make money, not the freedom to f*** ignorant people in the ass with deception.
You can find casters (wheels) pretty cheaply at Harbor Freight, but what I did was affix a couple of those large furniture "sliders" w/double stick tape to the ends of my ramps. I find it easier to store the ramps upright that way, as wheels would sort of get in the way; also, it's cheaper...you can pick up those slider thingies for ~$1/piece.
Jeff
New Threads
