Reverse Indiglo Gauges Installed! *pics*
yashart_mp3
Black Mica MS3
I got my gauges yesterday and decided to install them last night. The install wasn't as bad or as hard as i thought it would be. The gauges slid right over the needles with little effort. I took pictures last night as I was finishing up so the dash is not completely back together. I think i messed up somewhere though because the gauge dimmer no longer works...checked all the fuses and everything is fine. I disconnected the gauges and the dimmer still doesnt work. My dad has p5, so im going to pull his out and see if it works on my car... anyway, here are the pics! Enjoy
no, im scared to try... I probably will in the future, im just scared to mess that up. I still dont know why my dimmer does not work. I just ordered another dimmer switch, so hopefully that will solve the problem...
where to buy? and does it come with KMS as main measurement or MPH only?
it would go perfect with my cluster
I have a set of indiglo gauges and they were a b**** to get over the temp/fuel gauge needles! I snapped off the temp needle at the pivot and had to buy a whole knew IC. Not cheap, let me tell you...
Looks good! Is that common with those gauges that the dimmer switch doesnt work?
