Replacement headlights
Rittmeister
2002 Protege ES
Did a search, but mostly came up with HID-oriented threads...
I'm interested in trying to find a set of OEM-replacement headlights for my 2002 ES. Nothing ricey; I just want to replace the seriously nicked-up lights I've got with a clean set. Obviously budget is an issue; I haven't checked stealership prices but I'm betting they'll be high.
FYI, I have already tried polishing, but there's just too much wear.
Suggestions?
How did you polish them? Did you try wet sanding? I've seen some pretty good results with the right technique.
Otherwise, you can try e-bay or the occasional part-out on this forum.
Latest posts
