Replaced Battery...issues 2007 CX 7
Higgs44
2007 Mazda CX 7 FWD
Hi,
I recently had a dead battery, so I replaced. When I started it up, I noticed some minor issues. My driver side window panel button would not make passenger side go down, but passenger side button did. Also, window does not go down automatically with 1 push like before battery replacement.
TCS light came on and wouldnt go off.
Im assuming these are all diagnostic issues with computer? Any ideas, do I need to go to the dealer to fix this? I assumed they would be reset to factory specs with new battery, but not working correctly.
Any help would be appreciated.
Thanks....Higgy
There is a specific way to reset all the windows. I found it in one of the CX7 "HOW TO" LISTS. Look for it. The TCS light should go off after several start-drive cycles. Ed
Did you find what you needed to reset the window fuction Higgs44? Let us know. Ed
Been real busy, but i believe i found the page you were talking about, will try over the weekend and let you know...thanks
The TCS light did go off on its own like u said.
