Repeat TPMS Repairs
mjt5256
2009 Mazda 3 2.3L Hatchback
Hello all,
Just wanted to start off by saying that I am new to the Mazda forums, and I am happy to have found a place where I can come to ask for and also give assistance to those who need it, so thank you all in advance! Now down to business-
I have a 2009 Mazda 3 hatchback, 2.3L sport, with a 5 speed manual transmission. My issue lies in the TPMS system. This issue has been going on for two years now and I nor the dealership has come to a resolution. The TPMS light would start off blinking at random intervals, no beeping or anything just "blink...blink..blink" and then stay on for a few minutes and turn off. This had gone on for quite sometime. I have had all four sensors replaced twice, and have also had the keyless entry module replaced, which I was told by the dealership is the main computer that relays info to the sensors. After having all of this equipment replaced, today a new problem surfaced. If the light would remain on for an extended period of time, upon turning the vehicle off, the light would go off, and not come back on. The last week alone the light has blinked and remained on 3 times, more than ever so far in the two years this problem has been happening, and now if I turn the car off, as soon as I turn it back on, it will blink and then remain illuminated. I have turned the car on and off at four different times today, and it will not go off. Please help!!
Tire pressure is not low. 30 psi all around. Scan gauge hookup via OBDII port at dealership confirms pressures are within specs of the low pressure light illuminating. Dealership and operators manual confirms blinking light indicates system fault
