The way it was intended to be pulled out was not to reach behind and yank it out. The correct way to do it witjout ruining the tab is as follows: Drop down your glove box, remove it and set it aside, now reach your hand around the inner dash and there is a tab, press in the tab and push from behind the pocket. It should just slide right out. you do not have to remove your radio for this.
