Removing Passenger headlight assembly and Front Bumper
Iron League
07 CX 7, Sport FWD
I'm going to be removing the passenger headlight assembly to try to fix the broken wire spring harness thing. From what I see the tab is still in there and can be possibly re-attached with some glue or silicone. But doing this is going to mean that I have to remove the front bumper which is the only thing that makes me a little concerned. If you've ever removed it let me know if there is any tricks or potential issues. I will post pictures and description of this little project in the How-To forum.
Bumper cover comes off easily. 20 minutes max. Just make sure you remember where the plastic push pins go in, so that you can put them back.
