removing dash parts
Vegas3
How do I remove the AC control panel and center console between the seats? I now how to get the stero out but was unable to get the AC. Also the panel under the steering column. (dunno)
Panel under the Steering Column:
Remove the hood release (release plastic spring, pull towards you)
Remove single screw behind the hood release
Remove left kick panel (single push-pin)
Pull SC panel towards you, starting on the left, moving to the top right and finishing on the bottom right. There are four or five spring clips holding it in place and then a hook on the bottom right, to keep it from falling in your lap.
Can't help you with the AC control or center console.
