drop a piece of rope into the cylinder to prevent the piston from reaching top dead center should do it. make sure you can pull it out after.
my solution is much better and efficient...have done it on about 20 engines and works everytime!
put a 21mm socket to a breaker bar
connect the breaker bar to the bolt on the camshaft and leave hanging
make sure that the path tha the breaker bar will travel is free and that it will only hit a metal part
remove coil plugs
get in the car and give it a crank...car sholdn't start due to missing coil wireharness and the engine will take care of removing the bolt.
mind you this only works to remove the bolt...it will not work to tighten it back.
like i said, i do this everytime i need to rmeove that bolt and never had any issues...no need for an impact gun.
note: if it doens't remove it on the first or second crank, stop. execive force may damage the engine.
note: when i say crank, these are QUICK cranks, don't do it as if you were to start the car by holding the key on the start position, rather, give it momentary starts.
just hit the bolt with an impact wrench. Makes short work of it.
This, orPurchase the special shop tool.
This.Just get a universal crank pulley holder.
Just hit the bolt with an impact wrench. Makes short work of it.
OK - trying to remove the damn crankshaft pulley bolt on a motor that is out of the car on an engine stand. Impact is turning the motor over. Any other ideas?
remove coil plugs
remove coil plugs
LOL!. We all got owned. thanks magnumP5 & Tzar177
This, or
This.
Reading comprehension owns on this site...
