Reliability of bone stock MS3?
2007 Stock except a MSCAI and filled rear motor mount, though only at 29500 right now.
But recently just had some stuff done.
- Replaced front control arms (not 100% it was needed but the dealer wanted to make sure the clunk I was getting was completely gone.)
- Replaced front sway bar bushings and endlinks (same clunk problem, likely the bushings causing it)
- EGR valve was replaced because of the insufficient flow CEL but luckily I was still under the 3/36 and was covered.
-Replaced front shocks (all the clunking issue).
All that happened in October at 25,000
As I understand it, the TSB in question doesn't apply to the MS3. In any case, it's a moot point as I hope to sell the thing to Carmax as soon as the weather clears up a bit.
Yeah mine was replaced because of that code. Though others have successfully cleaned their's and the code didn't come back. So that might be an option for you if you keep it longer than that.
Replacing turbo's at low miles doesn't seem fun. How much is it for a replacement stock turbo?
Just bought a turbo on ebay for $180 and the rebuild kit is about $100. Interned knowledge for the how-to is free!
Stick with 2008 + 1/2 and/or 2009 MS3's with low miles if possible. Should be no problems. First model years of any car will have the issues taken care of during the following years. I got my 2009 8/09 and have no problems. Interior and exterior is nice in 1st gens IMHO. Electric stearing on 2010's is nice, until the battery goes out. Then you have no steering for 5 minutes after start up. Hence, I will take a power steering pump. With a set of Hotchkis sway bars on front and rear, the 2009's handle just as good as the 2010..... and no smiley faces or hood scoops.
for what it's worth....1 month away from its 3rd bday, but only 9k miles. A few mods [see sig line] , zero issues. Has been 1 pleasant surprise after another, in my experience...others may differ.
I have 70k on my 2007 MS3. Only issue I have had is after about 20k, when I get on it a little, it will buck and blow black smoke out the back. I have taken it to numerous dealers, but of course it wont do it there and they said the black tail pipe is normal for these cars(fight)
Appoarching 25k miles on my 08.5 and have no problems yet...only thing it might need soon is a new set of tires.
stock this car is like anything other new car. As soon as you mod your always gonna have some kind of problem.
So far I've replaced the idler pulley, and rear motor mount. 22K on it.
Sorry to thread jack: Were you getting a funny wine out of your motor cold when you went in to have that pulley replaced?
i get that every once in a while when cold, sounds like a belt squeak if i let off the clutch too fast from a start, wonder if i have the tensioner thing too...
How can you tell if the car is a 2008 or a 2008.5? Does it say on the carfax?
Thanks
08.5' have the glossy piano black trim on the inside. And if it's the GT, it'll have Alcantara seats.
35,000 on mine, stock. Put new Pirelli tires on it, that's about it. I don't drive it hard, and when I do push it I'm smooth.
New Threads
