How do I tap turn signal wires so that this led turn signal is setup on is own independent power but uses the original turn signal wire as a relay.
Perhaps I might confuse some of you but this is the best way to explain it
I have purchased led turn signal idicator lights but the folks at the shop told me to set them up as a relay so that you dont damage your existing turn signal by shorting out due to the voltage tap so set them up as a relay instead.
