Recommended Transmission work?
tonybonekhang
03 Mazda Protege 5
I just picked up a MSP6 and I think I need to swap out the clutch. It's current issue is that the clutch won't disengage so I am assuming the clutch got cooked to the pressure plate. I had to drive in home with rolling starts and rev matching shifts. Is there a pretty good change the Flywheel is still in good shape or should I go ahead and replace it?
Are there any other recommended repairs that I should do while I have the transmission out?
