Rear sway bar replacement questions
bmninada
Contributor
2016 CX-5 AWD GT+iActive Soul Red
Did anyone here replace the stock rear sway bar (not links) with a beefy one like Corksport or Progressive?
Does it help noticeably with side to side sway? KE model 2016 AWD 2.5L.
Also, is there any guide? 1 shop quoted me 7 hrs. Another 4.5. Another 2.5. Very confused.
It's involved because the rear subframe has to be dropped just like if you were doing springs and adjustable LCA's. I doubt the 2.5 hour quote is accurate. Probably 4-5.
IIRC you're staying at stock ride height with the Koni's, but if you have anything else back there you want to knock out at the same time, this would be the time to do it.
Ah well - thanks @N7turbo - really good you remember me.
Anyways - I think I'll skip it then. Just too big a cost on labor. Here in NJ its like $150/hr nominal these days and latest I am hearing many are even at $225/hr.
Debating should I go with KONI rear now that have KONI front. % benefit and while doing KONI rear (shocks) which is relatively easy anything else I should swap out while at it.
