Rear Sway Bar? AWR? Clunk?
Pyr0TeK
2001 Pro LX 2.0
Ok so I was wondering if the AWR rear swaybar has the same clunk issue as the stock MSP Racing Beat one? or are there others available (yes I know about the clunk fix brackets also).
I have heard things from different people, but none from people who actually have the AWR setup so please be knowledgeable if you post on this thread... no "I heards" please.
Only clunk I have had with my AWR is when the bracket broke. Apparently it wasn't their fault but it wasn't sitting right when mounted, otherwise I have zero complaints about my bar. You will enjoy the drive.
Me it was the adjustable endlinks only that would clunk. Otherwise no problems once everything was tighten properly with some threadlock.
Loved the bar but had to give back to my sponsor after Topeka Solo Nationals.
I have the 21mm and the adj. endlinks on a P5. I bought them used from a forum member and I've had intermittent clunk problems, seeming to stem from the endlink nuts getting loose on a regular basis. It was so bad that I lost all the hardware off of one end of one endlink at one point. When AWR sent me new hardware (for >$20) it included a NYLOCK type of nut, which I previously hadn't had. So, I got 3 more of those nuts, and installed them this week. We'll see if that takes care of it. I'm not sure if mine is so old that it didn't come with nylock nuts, or if the previous owner just didn't send 'em along, but it would appear that that's what AWR is using now, and for good reason!
I'd think so. I know the stock endlinks won't work on the 21mm.
