Rear Passenger door lock actuator
The passenger would be the Right side actuator. I just replaced the driver's side rear actuator in my car. It really isn't too bad it's just hard to get to, and you have to pull the door panel and avoid the black sealant stuff they use on the door. I dropped one of the two screws used to mount the actuator (and it somehow disappeared inside the door but it's working fine for now.
Just curious, I see you have a Profec B spec2. What are your settings and what boost do you run/spike? I am trying to dial mine in after installing the FMIC and i'm trying to see what works for others.
Kay, ill check the settings and tell you what I remember about them.
