Rear Pad replacement and EPB steps
geo55
2017 CX5, 30,000 miles ...So looking through the forum I found the procedure to put the Electronic Parking Brake into maintenance mode, so I can push the caliper piston back in. My question is after installing new pads and making sure the pad backing plate tab lines up with piston notch, with the engine off do I pump the pedal First to push the piston and pad onto the rotor and Then take it out of maintenance mode ? Thanks
Just press the brake pedal a couple of times while the wheels are still off and check if everything lined up fine, then exit the maintenance mode.
Latest posts
