Rear Door Adjustment?
FukuokaKid
2024 CX-5 Turbo Premium
Anyone know if there is any adjustments for the rear doors? On the lower section of the doors, where the driver door and sliding door meet, the line is kinda off. When you run your hand from driver door to sliding door, you can feel the change in height. The sliding door feels like it closes a little more than the drivers door.
update
I recently took the 5 to the dealer for a complementary service. While there I figured I would ask if the they could adjust the door. They said that they couldn't and it would have to go to a body shop. However, I did a little research and found that the adjustments are very easy. 2 10mm bolts on the top slide and 2 12mm on the bottom slide. Just remember not to remove the bolts just loosen enough to move the door. Also, do not loosen top and bottom at the same time.
<img src="http://api.photoshop.com/v1.0/accounts/150d93e082424234ab8cbd0fc88c307d/assets/34e1ea8e563d48ebbba092a21d2f3971" width="800" height="600"/>
<img src="http://api.photoshop.com/v1.0/accounts/150d93e082424234ab8cbd0fc88c307d/assets/edcacfd682414f5c8b01fc05b4a09f99" width="800" height="600"/>
Thanks!
I registered just to thank you!
I have the same exact problem and worse it makes squeaking noise.
I will adjust it tomorrow and hopefully it fixes it.
Fixed the rattle!
Took it to the dealer, they loosened the bolts on the top and pulled the door little away from the body.
It fixed the rattle completely. Got charged $75!
Thanks!
