lappracing
This is something I'm very interested in, but it's down the road a ways. If I were to do this I might consider upgrading the calipers front and back, too. Doing that would require a lot of research on my part, though, to make sure the brakes I get would work on the 2 and that front and rear are properly balanced. So, I'm eagerly waiting to hear if somebody else does this.![]()
We have already worked on this. If you are going to keep the stock front rotors/rotor size, you need to go with 250mm rear rotors. If you go with larger 300mm front rotors, you should go with the 280mm rear rotors. Either set-up is very well balanced.
