You don't use a c-clamp to compress the rear caliper. If you look down into the bore you'll see two notches in it. You can go down to a parts store and either rent or buy the tool. It goes on a 3/8 ratchet and you screw the caliper back in. And yes you will break C-clamps trying to compress it
Incase you need a new caliper assembly, I just received mine including bracket from amazon.com and it was only $66 shipped. https://www.amazon.com (commissions earned)
Rockauto has the correct calipers, one is listed as 'MPS-2 suspension'.
